I have a new Sony XBR 75-940c 4k tv. Viewing and audio is perfect through direct tv and my Anthem D2v 3D preamp.
The Netflix software as well as Amazon prime ultra app software in the TV are great visually with Ultra hd coming through fine.
BUT, the audio will not push through the HDMI4 arc connect. I'm have to use the optical out, but obviously not getting what through hdmi could do. Checking with Anthem forums hdmi (arc) is not available. For a 9 thousand dollar preamp that is disappointing.
I also have an OPPO bn 105 player, but the Netflix is no where as good as through the Sony Netflix.
Help. I'm doing something wrong.
Amps are Mcintosh 601's Mac 8207 for surrounds. speakers are Revel Ultima 2 studios. And Revel Voice2.
Thanks.
You are not really missing anything. HDMI audio return is the same as quality the optical out. You only get 2 channel and no loss less codecs. Very lame indeed.
The real issue is that for fine audio, you do NOT use the TV as the source ever. Once the TV is set up you only use the on off button. You should think of a TV as the video equivalent of a speaker. In other words a TV should just be an end device. The TV is just a very dumb lace to put a lot of features.
You need to select devices with the features you need to connect to your pre amp. I know the problem is that a lot of pre amps and receivers do not pass 4K video yet.
Now at 12 ft viewing distance there is really no advantage of 4k over 2k. 4K is way over sold, and certainly not worth downgrading audio for.
Remember 90% of the HT experience is audio, and 10% video.
