HDMI and digital optical cable
ToniScot
ToniScot
Hi, there! Which cable does the soundbar use? HDMI and digital optical cable?
Trebdp83
You can use HDMI if the TV supports ARC/eARC or the optical cable if the TV does not support ARC/eARC.
ToniScot
ToniScot
This is the difference. Thank you very much for your reply.
BMXTRIX
BMXTRIX
If you provide the make and model of both your television and your soundbar then we can provide you with a better answer.
Some soundbars don't support optical. Some don't support HDMI. If your soundbar supports both, then you will need to see what your television supports. Once again, some support HDMI for audio (ARC/eARC) others do not. Most have a optical audio output, but not all do.
So, it's hard to give a actual specific answer on such a vague question. But, the previous answer does kind of hit the main concept.
ToniScot
ToniScot
I have bought a few weeks ago the Q70T QLED 4K UHD HDR Smart TV and the HW-Q60T 5.1ch Soundbar w/ Acoustic Beam.
Trebdp83
The TV and soundbar support ARC. In TV settings, turn on Anynet+ for ARC activation. Make sure HDMI cable is connected to the ports marked (ARC). TV port should be labeled (eARC) and soundbar (ARC).
