having problems with pioneer vsx-d511
W
wildplumdx
hey guys just of late i been having issues with my pioneer vsx-d511 i know its an old amp and wasnt expensive to buy, anyway wee while ago it just gave up on powering my amp rest of the unit is fine,ive also tried every setting poss like 20 times to see if it was a set up prob but no luck, is there any tests you can do too see if the sub channel or output is blown or something ? must be something with a multimeter ? i have no idea.... thats why i'm here, i'm running Athena Speakers and sub which are two floor standing front speakers "as f1 2b1" and a center speaker "as c1 2b1" and the sub is a "as-p6000" also maybe my sub has packed up maybe ? maybe time for new amp, i dunno any help would be great
Adam
Adam
Hi, and welcome to the forum!
I want to make sure that I understand. Is the problem that your sub is no longer putting out sound? If so, then we can narrow down if it is the receiver or the sub.
Are you using the line-level input to the sub, or the high-level inputs?
W
wildplumdx
yeah isnt putting out sound altho it wont turn itself on anymore once the amp tells it too or whatever they do, if you manually turn it on you cant hear it going but the cone has small vibrations if you touch it well has minimal sound have to be right up next to it, basically not running,also running line in what the diff between the two as it has the high level on the back also ?
Adam
Adam
The line-level and high-level inputs are two different ways of sending the signal to the sub. The line-level input will already have the higher frequencies filtered out, but the high-level inputs won't. The line-level is the best choice, but if it isn't working (as yet to be determined), then you might have the option of hooking it up using the high-level inputs.
If you have the sub set to automatically turn on when it gets a signal, but that isn't happening, then that means that the signal being sent to it isn't high enough to trigger the auto-on.
A few questions below, some of which reference your owner's manuals for the Pioneer and the Athena:
1. Are your speakers set to "S" (i.e "small")? See page 30 of the manual.
2. What is the crossover frequency setting on your receiver (100 Hz, 150 HZ, or 200 Hz)? See page 30 of the manual.
3. What is the crossover frequency setting on your sub (the knob on the back of the sub)? See page 3 of the manual.
4. Is the subwoofer set to be on in your receiver's menu? See page 30 of the manual.
5. What is the LFE attenuator setting on your receiver set at (0 dB, 10 dB, or ** dB)? See page 31 of the manual.
One way to check if the issue is with the amp in the subwoofer or the signal being sent to the sub is by plugging another component (such as a CD player or DVD player) directly into the sub to see if any sound comes out. Let's hold off on that for now until we step through some of the other possibilities (which are quicker to check, I think).
Adam
Adam
One other thing that I didn't mention above that shouldn't be involved in the auto-on not being triggered, but might play a role in the sub being so quiet, is the volume knob on the sub. Make sure that wasn't accidentally turned way down.
