bruin62 said:
I would like to spend around a thousand. for 7.1 did you happen to check the links?
I did look at these, however I wasn't sure if you were just looking at a full 7.1 package or otherwise.
I have seen some positive feedback on the Fluances, very little on Streem. Axioms are manufactured in Canada and have an excellent track record, but a 7.1 system from them likely wouldn't make it under your budget unless you went used.
AV123 just recently released a 5.1 system for just under $700 that looks fairly impressive (
see this link. Add another pair of bookshelves from this package for 7.1 and with shipping for both, you should be right around your budget. I believe they ship to Canada, but I'm not sure of the cost. The folks at AV123 have excellent customer satisfaction, so I'm sure they'd be willing to answer and questions you have via phone or e-mail.
I would suggest the SVS SBS-01 package, but I know several folks have mentioned fairly high shipping rates to Canada for thieir subs. This, coupled with a 7.1 system b/f shipping would come in at $1,149, already over your budget.
Another option might be finding some BIC Venturi speakers that have been frequently noted as excellent budget speakers. In addition to this, they can be modified to yield even more impressive results.
Here's a good link describing some folks who've either done this or have experience with this.
As far as your question regarding surround sound speakers, bipole/dipole type speakers can provide a better solution for predominantly home theater/movie listening setups as they diffuse the soundfield offering a larger, less localized soundstage. Some folks prefer direct radiating speakers (typical bookshelf or on-wall type) for multichannel listening environments. Some also prefer the more localized surround stage direct radiating speakers offer, so it really boils down to preference. Unless you have a really large listening area, towers aren't necessary and would likely be overkill.
For surround back placement, I found keeping them spread equal to the front mains gave me the best rear soundstage. I've seen the THX recommendation you mentioned, but I think the surround and surround back configuration can vary quite a bit depending upon your listening environment and tastes or preferences.
Now if you'll excuse me, I'm going to ice down my fingers to avoid typer's cramp after this short novel...
-TD
-TD
