Have pioneer 503 elite want to add amp looking at outlaw7000 or monolith 7 willthey work with pioneer was told preouts main channels have 1volt so
Paul s
Have pioneer 503 elite receiver looking at outlaw7000 or monolith 7 was told main channels have 1 volt on preouts will they work and would i get all out of amplifiers
Movie2099
Either of those amps would work just fine with your AVR. I have the Pioneer SC-LX701 paired with an Outlaw 5000. I'm using the amp to power just my front 3 and leaving the AVR to power my 2 surrounds. Works perfect.
Paul s
Hi reason asking outlaw said unless 1.2 volts wouldn't get all the watts out of amp?
Kingnoob
Kingnoob
How good is outlaw it a ultra a premiun brand?
I’d need a much larger room to need an external amplifier... onkyo 818plenty of power
Movie2099
I don't think you'll have to worry about the voltage. If you feel the Pioneer isn't up to the task you should check out Denon, Yamaha or Marantz. Right now the Denon x3600H or x3500 is very popular AVR.
Movie2099
The Outlaw amp is very good. I'm not sure what you consider "Ultra Premium", but they are the best bang for the buck.
For some an AVR is all you need. If you have speakers that need lots of power to get the most out of them, most likely an AVR will not provide that. You'll need to get an amplifier.
Paul s
Tried yamaha too weak besides pioneer only year old not in hurry to replace hoping someone had answers if volts would mske difference help line really dont know there just reading screen
Movie2099
You won’t have any issues with voltage. That AVR is made to add an external amp. I don’t have specific breakdown with numbers, but I can assure you a 7 channel amp will work perfect with your AVR.
Do you listen at extreme levels at all times for long periods of time? Just curious about your voltage issue.
As mentioned in your duplicate thread, the 504 and 303 have both been measured at audiosciencereview to show output well above 1V.
Pogre
Pogre
Too weak? As in it didn't get loud enough? Which Yamaha did you try? What kind of speakers do you have and how far do you sit from them?
Paul s
Somtimes especially playing music
Shut down after awhile dont remember # got it at Costco should have known better using 2 klipsch rf82 2rp8000 polk on rear center and have 4 primus363 for other room but they are closer to 4 0hm one reason for amp
Pogre
Pogre
Wait, what? You gotta slow down a little... and mebbe try some punctuation, lol. So you have 8 speakers hooked up how? What does "2 RP8000 Polk on rear center" mean? Do you have 2 or more speakers wired in parallel to the same channel(s)?
Paul s
9 not counting subs none wired together 82sfront '8000 side surround polks upper back surround polk center 2 klipsch upper hieght
