Have HSU mk5hp (thx shadyJ) but looking for another
N
NoPAspeakers4me
That post made a ton of sense Ryan. Now I’m convinced the SQ of my placement is poop. I’ll try different placements and use the AVR to help.
ryanosaur
ryanosaur
If you haven't done it before, try out the Subwoofer Crawl. It's crude, but you can also learn a lot about your room and the way bass sounds as you change positions in your room. If you do this with an open mind and a good deal of patience, you should be able to figure it out. The first time I tried it it took me around an hour to do. The most helpful thing to me was crawling into and out of my worst corner. I really began to understand the differences in SQ with that. If you can, look for 2-3 good places where the Sub sounds it's best, remembering that loud isn't necessarily better. ;)
Once you do that and hopefully find a better home for your Sub(s), look at your setup for the mains. Do some reading on proper speaker placement for best sound. Little things you do in your room, what we sometimes call "positional EQ" are free and easy to experiment with. :)
When you find some good spots and get things setup, run your room correction. Try out the new setup in small sessions.
Have fun, and enjoy the process! :D
N
NoPAspeakers4me
Thanks. Yea I did the crawl for my living room system but figured the bedroom would be pretty straight forward. Will do.
