Harmony 880 and HTPC
dalessandro12
Can I use my 880 to control my HTPC? I have a Windows remote with IR and I tried to "teach" the remote but haven't had luck so far. I am new with the Harmony so maybe I am doing something wrong.
Also, does anyone know how I can have Boxee automatically start when the computer boots? I am sure there is a way and I am Googling it now, but just thought I'd ask.
Thanks
BoredSysAdmin
BoredSysAdmin
I have boxee on Zotac Ion and Mini ITX case, newest Boxee running on Win7
For Remote - I got Dell MCE IR Receiver off ebay and Programmed my Harmony 880 to use Microsoft MCE Keyboard as device for HTPC - you can find most of key mapping in boxee/xbmc forums...
http://forum.xbmc.org/showthread.php?t=33825
99% works fine
dalessandro12
99% works fine
Thanks for the link but I'm a little confused. How do you program the 880 to use Microsoft MCE Keyboard mapping?
BoredSysAdmin
BoredSysAdmin
Add new device in harmony software: Computer/Media Center PC/ Microsoft/MicrosoftMCE Keyboard
and custom map keys in activity
dalessandro12
Thanks BoredSysAdmin, I've added the device and mapping the keys now. Wish me luck.
dalessandro12
Ok it looks like everything is good now. I added the MCE keyboard and had to map a few keys (like the "Back" button) and I think everything is good now. I created a new activity that starts the HTPC, TV and receiver.
Now if I can only get Boxee to start at boot. I tried copying the .EXE to the Startup folder in Windows 7 but it was a no go. I found a registry hack to replace explorer.exe with Boxee.exe but I would like to try that as a last resort.
Anyone no how to do this?
Thanks again BoredSys!
BoredSysAdmin
BoredSysAdmin
Well, just copy and paste boxee shortcut into StartUp folder in win7 - works like a charm.
