Hey all. I just got the Harmony 1000 and it easy to use except the software doesn't give you the freedom to do advance customizations.
First: I have my DirecTV HD DVR box set to receive RF signals instead of IR, but the 1000 doesn't work and only works when I switched the setting to IR again.
Second: I have a media center setup and I need my TV to change to HDMI2/DVI and then the receiver switched to CD in order to operate see and hear the computer, but when I want to do this it wont let me without adding another media device. (I select "Listen to Music" and I have also tried "Listen to CD") So I have to have the DVD player also included, so now it will turn on each time I click my preset "Media Center" button on the screen, but all I want is just the TV and Receiver to be functioning.
Any ideas on how to fix these two problems?
Also, I use a wireless keyboard, so my media center has a USB RF receiver plugged in. You think the 1000 remote could be programmed to work with it?
Thanks for your help!
