Matt34
Matt34
Moderator
So I guess this goes off your IP address but Google search defaults to Korean no matter what I've tried. I keep having to type "google in english" in the search bar before doing any searches and it's annoying. Anyway to permentaly set the language settings to English?
mike c
mike c
hmm, mine remembers to go to plain google.com instead of google.com.ph (google.co.kr for you) once i clicked on "google.com in english"
GirgleMirt
GirgleMirt
What browser are you using? Have you tried clearing your cache/cookies? Are you signed in iGoogle? You could try logging in/out see if that makes a difference.
1
10010011
Had the same problem about a decade ago in Paris. Google kept defaulting to google.fr, even if I typed google.com. But I can not remember how I got around it.:confused:
JoshK
Matt,
-Go to Google.com
-Put your cursor to the right of the search bar. You should then see *Languages*.
-Click Languages, then you have the ability to immediately change your default language preference.
Give that a shot and let me know if that worked for you.
Matt34
Matt34
Moderator
