Good Looking Speaker Cable
Shock
Shock
I tried to search but it keeps timing out on me. Anyways, I'm looking for some nice looking wire 6-8ft in length for less than $150. Banana termination is preferred.
These are in the running atm:
http://www.ascendacoustics.com/pages/products/access/cable/matrixspkr.html
Those do look quite snazy.
If you have the patience and the time, you can do a really nice job of making your own twisted pair cable. I was bored one day a few months ago and decided to completely seperate my cables and spin them back together. I first stripped the two cables from each other then spray painted them blue and white. I bought this so called "plastic" spray paint that is "supposed" to bend and not crack, yeah what a bunch of crap. They should have branded it "Monster spray paint" since it was such a load of garbage. Anyways.......I ended up just using the strands untreated.
Following this i tied one end of each cables to a door knob, and begun weaving the cables into each other, over and over again. I did learn that unless you have a lot of room you don't really want to work with anything over 6 feet, or else you can't get the cables tight enough to hold their twists.
At the end i got some simple skrink tubing and finished them off about 6 inches from each end. Added some monoprice closed screw type banana's and used heatshrink on those.
Honestly the hardest part was going to the basement apartment and asking the girls for a hair dryer and still try to look manly. It did take a good hour to do all the twisting, including a few failed attempts at making the twists look even.
But in the end it came out better than I thought, and currently it's providing the cabling to my centre channel.
If you have a few hours to kill, and no one around you might want to give it a try. I say no one around because you look rather silly while your braiding them......
mike c
mike c
what about a techflexed monoprice/BJC speaker wire ... DIY of course. didn't you do some already?
Matt34
Matt34
Moderator
I had some made for me but the cables have all pulled out of the banana plugs. I still have a bunch of techflex and quadstar cable laying around from about a year ago but making cables was never very attractive to me.:D
nibhaz
nibhaz
Cobalt cable has http://www.cobaltcable.com/speaker-cable-pair.htm
6.6 ft 10 AWG for $135 link to pic below:
http://www.cobaltcable.com/speaker_cable_popup.htm
I got them in blue a few years ago. Don't know the color selection now.
I have these cables going to my front 3 channels. I’m by no means suggesting that they are the best value, or most stunning look, but mine have survived 4 moves with out any sign of physical distress, which is actually irrelevant because Cobalt offers a lifetime guarantees on their cables.
Sure, 10ga is over kill, but I say why not?:p
Rickster71
Rickster71
I'll bet you couldn't resist the, reusable Ultralink carrying case. :)
Matt34
Matt34
Moderator
Yo Matt! You have pictures yet?
Yes I do, the previous poster reminded me of them :eek: but I have to wait until my wife gets back with the camera as they are on the memory card. I can take some pictures with my BB but they will look like dookie.
nibhaz
nibhaz
Sweet, no rush!
I've reconfigured my front sound stage, and need some much shorter cables. I prefer pretty, yet functional cables so maybe these might fit the bill for me.
