Good Cable TV line splitter
boe
Are there any brands that make better ones than others or are they all about the same?
Thanks
markw
I'm using two way's from Sears and they work fine.
Of course, you can spend as much as you want but unless there's something radically wrong with them, there's no reason they should be too different.
TMASD2002
Thanks
Boe, most splitters are basically the same as far as features and functionality. Unless you are doing something specific. If you are on digital cable with a cable modem you will want to make sure you get a high frequency splitter in the 1ghz or higher range.
http://www.avcablesource.com/CABLETVSplitter.html
Hope that helps :D
