Good Amp-Speaker Match
E
eddie
I am considering the purchase of either an Athena Audition f-2 system or the Axiom Epic 60 system. With either of these speakers what receiver would be a good match? I'm considering 2, the Onkyo 803 or the Yamaha 2600. I know that they all have different characteristics sonically, but, of the equipment I'm considering, what would give me the best sound for the dollar. I have a med size room 15x20 square feet. I also use my system for movies much more than music, however, when I listen to music, I tend toward R&B, jazz and some classical. Somewhat bass-heavy I suppose. Thanks in advance for your replies.
hifiman
hifiman
No offense, but you're asking a question only you can answer. You've limited your choices to a manageable number, now pick something and try it out. I suggest starting with whatever is easy to return for a full refund and start from there. If you like it then fine you are done. If not, you start over again.
Actually, sonic characteristics should be the last issue to worry about since that has yet to be demonstrated.
What you should concern yourself about is the receiver's flexibility to meet your processing needs and the power to drive your speakers to the desired levels without clipping the amp. So, your speakers impedance, sensitivity, distance to listening position have bearing on which you should seriously consider. Do you have a powered sub? That too has an bearing.
Buckeyefan 1
Buckeyefan 1
Check to see which receiver has a graphic, as well as parametric eq. Those that have them are easiest to tailor to your tastes. The newer units utilize these to balance out room issues in auto setup. I like to see the auto setup run, then take it one step further and tailor that balance to my taste.
jaybirdmusic74
jaybirdmusic74
i need to beat my brother in law
I am currently in a bigger race for audio, than the arms race between the usa and russia.
My brother in law just added a NAD T973 ( I think thats it) amp to go along with his polk audio rti10's and csi5.
I am looking for an amp to compliment my definitive bp7004, clr2500, mk80
jcPanny
jcPanny
Speakers for HT
Eddie,
The speakers (and the room) have the most impact on the audio capability of your system. I would consder a less expensive receiver if necessary to afford better speakers like the Axioms. For example, a Yamaha RX-V2500 or 1500 ($5-600) would work well with the Axiom M60 system and same you $5-600 for your speaker budget.
F
Fl_Gulfer
About 75% of the sound is the size and shape of the room, You really need to bring stuff home and try it first. If you go to a good store they will do set-ups for you.
highfihoney
highfihoney
jcPanny said:
Eddie,
i agree & its good advice.
