Ok so i bought myself some nice speakers.. and i bought some decent electronics, now it's time to properly hook it up. I've read the two guides about speaker cables and that some cables are way over-priced and could actually sound worse than others.. I've read alot about banana plugs and soldering.. I couldn't really conclude what would be the best bang for the buck or really who makes a good cable or what a good cable consists of.
People talk about banana plugs good because wire becomes oxidized but this seems sill because even though the plugs are gold plated the wire that is screwed into the plug and WILL still oxidize.. so i've concluded that if i plan to move stuff around alot i'll use banana plugs. However i would buy the solder banana plugs and that would make it so there isn't any bare wire eliminating oxidation.
I'm good at soldering and have all the proper equipment so i wonder if it would be good to just put some silver solder on the end of a decent stripped back wire and call it good.. or is there better solder i should use?
Now for all of this to work i need to choose a wire. I definitely know that for lack of resistance i want a decent gauge, thats the easy part.
Can i get away with going down to radio shack and buy 12 gauge wire, put some solder on the tips and call it good?
Do i need better wire? If so recommendations?
Kind of a run on everything sorry.. but i'm confused so to recap:
Questions:
what type of solder (silver, rosin core, ???)
what kind of wire (braided, shielded, flat, high strand count, oxygen free, etc, ?, whatever else is out there) ?
thanks, i'm lost..
