adwilk
If you want to go under the carpet, you can use a razor knife to cut a "track" in the bottom side of the carpet pad and run the wire through it. you'll feel it a little when you walk on it though...
I have the same new house and am struggling to figure a way to go for the rear speakers all the proposals have been considered and am still searching .Have been exploring flatwire solutions.It comes very flat and has an adhesive side .installation is put it on the wall an spackle it ,sand it and paint it.Has any one had experiences with this flat wire process.I would appreciate some feed back. Thanks...I've just always picked wire that blended well with its surroundings.Maybe I should try some of these ideas!
You can get flat 'ribbon' cable to do a carpet pull with.If you want to go under the carpet, you can use a razor knife to cut a "track" in the bottom side of the carpet pad and run the wire through it. you'll feel it a little when you walk on it though...
