Give me speaker suggestions for my setup!!
cerebrex
Well guys, I'm almost ready to purchase everything, however I really want to get some suggestions on speakers. I want them to match up well with the components I have, and keep it under $2,000 if possible. It will be for a 5.1 system which will eventually be expanded to 7.1 at a later date. The system will be used for about 95% Home Theater and 5% Music.This will go in a room that is 18 x 19 ft.
The components I have set aside so far are the following:
Panasonic 58pz750u 1080p HDTV
Onkyo 805 Receiver
SVS 20-39 PC Plus Subwoofer
And various gaming machines....
Thanks for any suggestions!
mazersteven
mazersteven
Get out and audition as many speakers on your own as you can. Bring your own material to audition like CD's, and DVD's. Take your time and don't rush. Have fun, and take notes. Make a decision if your going to do just speakers now and maximize your $2000 with speakers only. Or suck up most of your $2000 in a sub to fill that 18x19 room. If it was me I would purchase just speakers for now and run without a sub till funds where available. Or increase budget now.
Paradigm
B&W
PSB
Monitor Audio
Kef
Klipsch
Polk Audio
Internet only
AV123
Swan
SVS
Ascend Acoustics
ParadigmDawg
ParadigmDawg
I think Steven has stolen my master list so I am really just repeating what he said.
You have to go audition as many speakers in your price range as you can.
Here is a list of my favorite most of which I auditioned 5 months ago.
Paradigm studio series
Warefedale Evo series
PSB Image series
KEF IQ series
Monitor Audio RS series
Ascend CMT-340
AV123 Rockets
Aperion Intimus 633
cerebrex
So those speakers suggested would be ideal matchups with my receiver, subwoofer, and room size? As far as teh $2,000, that's just for speakers. The sub is separate, as noted in the first post. Thanks for the suggestions.
ParadigmDawg
ParadigmDawg
The AVR really doesnt play into this much as far as your room size is concerned. The sub is the most important thing to look at with room size. All the speakers listed here are 8ohm (I am pretty certain) so your AVR should be fine.
Joe Schmoe
My Boston Acoustics speakers replaced some significantly more expensive B&Ws, and I like them better. The prices they have been available for lately are an absolute steal.
Of course, it is hard to go wrong with most of today's speakers. Aside from Klipsch (which I find too bright) and Bose, I haven't heard any that don't sound good.
mazersteven
mazersteven
$2K just for speakers Awesome.
Are there any restrictions or needs for these speakers? Like Wall-mounted, Bookshelf, over Floorstanding, Di-pole Surrounds?
cerebrex
There's no restrictions, but I do have preferences. I would like them to be bookshelves for the mains, and wall-mounted for the surrounds. If I do 7.1, I will have the "sides" probably in the ceiling, and the rears in the back wall? Will having the side surrounds in the ceiling be absolutely terrible for sound?
mazersteven
mazersteven
Again you can maximize your budget by going 5.1 for now and adding later.
rnatalli
Definitely take your time and try and audition some brands at local stores. The internet sellers typically offer a 30-day trial as well. Since you're 95% HT, I'd probably go with the brighter speakers such as Axiom, Boston Acoustics, etc... That's not to say musical speakers like Tannoy, Mirage, KEF, etc... speakers won't sound great as well for HT. It's all a matter of taste. It's best to give everything a listen and let your ear decide. I personally like Mordaunt-Short as they're very detailed and not overly bright so good for both HT and music. I also like the PSB's I've heard. You have some really good options with a $2k budget. What kind of sound do you generally like? Is your receiver rated for 4 Ohm loads?
dem beats
Having a preferance is a good place to start. A word of advice sir. I would avoid in wall in celeing.
It does not maximize the potential... Maybe for that new 11 channel yamaha to have the ambient noise come from the sky would be real choice.. but I just dont see the reflections and the sound waves working properly being directed from the ceiling I'm straying from the point.... also in wall.. well... cabinets are made the way they are for a reason... If there are brands that make in wall cabinets with the same build quality.. cool, but you won't have a port that is tuned so you will miss something....
I would start 5.1, you may be suprised how satisfied you are! I'm over joyed with what I have, I could use 7.1, as I nearly exclusively watch big epic movies and almost all are in 7.1.
One more note.... If you can tell us what you would like to hear in a speaker and a referance point. i.e. "the b&w 803's were ok, but i want more in the mid range and a wider soundstage also they looked goofy I like a more standard look and want such and such a wood grain... etc etc." Then we can surely help you in the right direction.
the other thing you need to do is audition. then audition some more. then when you feel you decided listen to some more... and then a few more. You can't sample enough. It's only anxiousness that will force you to buy. I recomend to check out specialty shops in your area also.... big stores like BB and CC will have some ok stuff, heck you may fall in love, but also go to the small localy owned shops... those folks will be ready to impress.
Joe Schmoe
I use my Bostons exclusively for music. They fall very much into the category of highly musical speakers. They are also neutral rather than bright.
AVRat
AVRat
Looking at your room layout, where were you thinking of placing the surrounds? I can understand the rears on either side of the entryway, but what about the sides?
cerebrex
Alright guys- Yeah, the layout of that room is TERRIBLE. But anyway, I decided to buy a Studiotech U22T TV-stand and put it on the wall next to the glass door. So the mains will go up there. With a couch about 8 ft out. So, as far as where to put the surrounds, I have no clue. Open to any suggestions, though!
Thanks for the advice so far!!
mazersteven
mazersteven
That means your rears would be on both sides of this.
Are you going to try to squeeze your television between the fireplace and glass doors?
ParadigmDawg
ParadigmDawg
I have no issue with you using in-ceilings for the surrounds; it goes against most peoples opinion on here but in the real world you have to compromise. I use them and they sound really good for surrounds.
mazersteven
mazersteven
I agree with a nice set of Speakercraft AIM8's for surrounds. Or Speakercraft AIM8 Wide's.
www.speakercraft.com
You could mount the television over the fireplace then. If that's where you want to.
cerebrex
Yeah, I'm going to put the TV in between the fireplace and glass door. I wouldn't call it a squeeze though, as there's 8 ft. of room there.
Above the fireplace is not an option simply because it's way too high.
So should I get some in-walls or in-ceilings for surrounds in that situation?
mazersteven
mazersteven
Take a look at these systems. They use dipole surrounds that you can mount on the rear wall giving a diffused rear sound-field.
http://www.av123.com/products_product.php?section=speakers&product=12.1
http://www.av123.com/products_product.php?section=speakers&product=11.1
They also would match your room?
