Dan Banquer said:
I am going to take a few minutes here to explain to you home theater folks about power and how it relates to the bulk of HT, so please bear with me.
Typical music program material has the highest amplitudes in the bass region of music. In a typical home theater configuration this is sent to the powered subwoofer, and not to the receiver. Since the highest amplitudes and therefore the highest power consumption is now with the powered subwoofer the reciever has just been relieved of it's biggest "headache" so to speak. The receiver at this point will expend most of its power on the front three speakers and typically very little on the rears. In addition the great bulk of HT speakers are typically 90 db spl and 6 to 8 ohms in impedance. No great current pumping going on here, especially when you consider the average listening level is 80 db spl at the listening position. In conversations with GDS he has typically measured peaks at that level of less than 100 db spl for the main speakers. Given typical room size, anything more will not only be over pressurizing the room but possibly pissing off your neighbors. At the moment GDS and myself are estimating that a solid 50 watts rms into 8 ohms for each of the front three channels will probably do most folks just fine.
For you old stereo folks you have to remember that we are longer have just two speakers powering a room, but 5.1 speakers, and therefore the average power drops per speaker, with the exception of the subwoofer.
All for now;
Dan Banquer
R.E. Designs
I couldn't agree more. That would be typical alright. But there are many exceptions to this. Not every audiophile you meet has a subwoofer. I know many whose multichannel set-up is not only for HT but for SACD and DVD-A that, because their players and receivers do not have the required bass management for such sources, use identical full-range speakers besides. Many SACDs and DVD-As do not have the .1 LFE information to drive the subs. In fact, there are some DVDs that do not have .1 LFE in their tracks at all.
But confining our discussion to 5.1 HT, your erudite explanation applies most convincingly to satellite-sub combinations and to set-ups with sub crossover point set at 80hz or more. I crossover my sub at 45hz. Hence, for all intents and purposes, my main front speakers and even the back are still dishing out the full audio spectra down to their lowest at 50Hz, -6db at 40hz. Depending on the DVD material, the rears can actually extract as much power as the fronts or contain as much bass. Not always, but it helps when the rear channels and speakers are up to the job.
And yes, 50 watts per channel in a 5 channel receiver is arguably the most one needs in a typical listening HT room to extract the most visceral aural realism one can get out of those mega blockbuster DVDs. The sub should take care of the power hungry low frequencies, indeed, relieving the receiver amps to deliver relatively lesser current for the mids and highs. Putting it another way, the receiver can now devote more power to the mids and highs when required. I hope your recommend 50 watts includes peak dynamic headroom abilities in the amp. Does it? Have you heard how a 50wpc amp with constrained or no headroom sound vs one with sufficient headroom? Thanks.
