FS: PMC two two 8 Studio Monitors
s91
A pair of fantastic monitors from the English manufacturer PMC, model twotwo.8 are offered for sale in perfect working condition. One monitor is only unpacked for photos.
These active boxes are characterized by the excellent localization, transparency, details and natural and deep bass reproduction, it is not for nothing that the PMC boxes are used in the best mastering studios worldwide. The built-in DSP device enables various settings at the push of a button
Technical data below:
Active Benefits:
Accurate powerful sound
Higher SPL with lower distortion
Improved on and off axis response
Specification:
Versatile positioning - perfect in both vertical and horizontal orientations
State-of-the-art, audiophile, high-efficiency dual Class-D amplification
Best-in-class connectivity - both analogue and digital up to 192kHz
Powerful DSP engine for driver, crossover & EQ control
Crossover Frequency: 1.8kHz
Frequency response: 35Hz to 25Khz (+/- 3dB)
Amplifier power for HF: 50Wrms
Amplifier power for LF : 150Wrms
Tweeter: Single 27mm soft dome
Woofer: Single 200mm
Input connectors: Balanced analog XLR, unbalanced RCA/Phono, AES digital XLR
Effective ATL™ Length: 1.9m
Mass / weight:
500mm H x 250mm W x 415mm D
12.2 kg / piece
They're in excellent cosmetic condition and sound incredible; They also come in the original box.
The twotwo series combines PMC’s world-class design pedigree with sophisticated digital signal processing and active amplification to create a range of stunningly accurate, versatile, and compact two-way reference grade monitors.
Asking Price is USD$4000 for the pair
If you are interested, do send me a PM or email:
iansas91 at gmail dot com
Thanks you for your time...!!!
