Mint condition speakers.
Black Walnut
Purchased at end of production.
Approximately 650 hours of use.
Not run at full range.
All packaging and materials included.
Local Pickup Preferred
Cleveland, Ohio (44022)
Shipping available at buyers cost
$3000
Original Retail Value for package - $5700
Prestige 85F Specifications
DESIGN4-driver, 2-1/2 way floorstanding
CROSSOVER2nd order electro-acoustic at 2.0kHz (tweeter/mid); 2nd order @500Hz (mid/bass)
HIGH FREQUENCY DRIVER1" (25mm) X-PAL™ dome, ferro-fluid damped / cooled, Perforated Phase-Aligning (PPA™) Tweeter Lens, Finite Element Analysis (FEA) optimized pole piece assembly
FREQUENCY RESPONSE ON-AXIS±2dB from 40 Hz - 20 kHz
FREQUENCY RESPONSE 30° OFF-AXIS±2dB from 40 Hz - 17 kHz
MID/BASS FREQUENCY DRIVER6.5" (165mm) X-PAL™ driver, overmolded Active Ridge Technology (ART™) surround, SHOCK-MOUNT™ Isolation Mounting System, 1.5" high-temp voice coil
LOW FREQUENCY DRIVERTwo 6.5" (165mm) X-PAL™ driver, overmolded Active Ridge Technology (ART™) surround, SHOCK-MOUNT™ Isolation Mounting System, 1.5" high-temp voice coil
SENSITIVITY ROOM / ANECHOIC93 dB / 90 dB
LOW FREQUENCY EXTENSION29 Hz (DIN)
SUITABLE AMPLIFIER POWER RANGE15 - 350 watts
MAXIMUM INPUT POWER200 watts
IMPEDANCECompatible with 8 ohms
DIMENSIONS HXWXD ‡ INCLUDES PLINTH, FEET, GRILLE AND TERMINAL CUPS.41" × 12.125" × 14.75" (104.1cm × 30.8cm × 37.5cm)
FINISHESGloss: Piano Black, Midnight Cherry & Gloss White. Satin: Walnut & Black Walnut
WEIGHT57 lbs. (26 kg)
Prestige 55C Specifications
DESIGN6-driver, 3 way center channel
CROSSOVER2nd order electro-acoustic at 2.6 kHz (tweeter/mid), 2nd order @ 750 Hz
FREQUENCY RESPONSE ON-AXIS±2dB from 55 Hz - 20 kHz
FREQUENCY RESPONSE 30° OFF-AXIS±2dB from 55 Hz - 17 kHz
MIDRANGE FREQUENCY DRIVER3.5" (89mm) X-PAL™ driver, SHOCK-MOUNT™ Isolation Mounting System
LOW FREQUENCY DRIVERFour 5.5" (140mm) X-PAL™ drivers, overmolded Active Ridge Technology (ART™) surrounds, SHOCK-MOUNT™ Isolation Mounting System, 1.5" high-temp voice coil
SENSITIVITY ROOM / ANECHOIC94 dB / 91 dB
LOW FREQUENCY EXTENSION37 Hz (DIN)
SUITABLE AMPLIFIER POWER RANGE15 - 260 watts
MAXIMUM INPUT POWER190 watts
DIMENSIONS HXWXD ‡ INCLUDES PLINTH, FEET, GRILLE AND TERMINAL CUPS.7.75" × 32" × 13.125" (19.7cm × 81.3cm × 33.3cm)
WEIGHT49 lbs. (22.2 kg)
