For sale is a nice used Mcintosh MAC6700 stereo receiver. The unit is in pretty good shape overall for it's age and sounds amazing as expected.
Product:
200 watts x 2 channels into 2, 4, or 8 ohms
total harmonic distortion: 0.005% at 20-20,000 Hz
frequency response: 10-100,000 Hz (+0, -3dB)
signal-to-noise ratio: 95dB (line level), 84dB (phono MM) 82dB (phono MC), 113dB (power amp)
wide-band damping factor: greater than 40
built-in McIntosh Digital Engine up-sampling DAC for decoding digital audio sources
AM/FM tuner with 20 presets per radio band
built-in High Drive headphone amplifier
large power transformer with multiple filter capacitors and regulated power supply ensures stable, noise-free operation
patented McIntosh output Autoformers ensure every connected speaker receives full power regardless of its impedance
patented McIntosh Power Guard circuit prevents amplifier clipping to protect speakers
Sentry Monitor and Thermal Protection circuits provide long amplifier operating life and protection against overheating
Home Theater Pass Through mode allows receiver's amplifier to become part of a multichannel sound system
fiber optic illuminated glass front panel for a beautiful appearance and long-term durability
adjustable front-panel display brightness settings
illuminated power meters (with illumination on/off settings)
handcrafted at McIntosh's Binghamton, New York factory
Inputs:
USB (Type B) input for connection to a computer
supported bit depth and sample rates: up to 32-bit/192kHz
dedicated McIntosh USB audio driver required for playback on a Windows® PC
1 optical and 1 coaxial digital audio input
supported bit depth and sample rates: up to 32-bit/96kHz
1 set of balanced stereo XLR inputs
5 stereo RCA audio inputs
separate RCA phono inputs for moving magnet (MM) and moving coil (MC) cartridges
adjustable input impedance loading for optimum sonic performance with a range of MC cartridges (50-, 100-, 200-, 400-, and 1000-ohm settings)
IR input for connecting an IR receiver
Outputs:
custom McIntosh gold-plated binding-post speaker connectors with 2-ohm, 4-ohm, and 8-ohm output taps to match speaker impedance
full-size headphone output (20-600 ohms recommended impedance)
RCA preamp out/power amp input jacks
Other Info and Specs:
asynchronous USB technology for reduced timing jitter and better sound
bass and treble controls with tone control circuitry bypass settings for each individual input source
Power Control output provides convenient turn-on/off of McIntosh source components
6 Data Ports provide remote control of connected McIntosh source components
RS232-C connector for connection to a computer or other control device
17-1/2"W x 7-5/8"H x 22"D
weight: 76 lbs.
Asking USD$4250 or best reasonable offer.
You can message me via PM or email: iansas91 at gmail dot com
Thanks for looking..!!
