FS Martin Logan Mosaics (Black)
tarigaad
Martin Logan Mosaics (Black) Speakers
I have a pair of black Mosaics for sale in Central NJ. They are about 6 months old and have been very lightly used. They are my rear surrounds. I will be buying a pair of Frescos to replace them. I have the original boxes and manual. I can ship but local pickup is preferred. Pics upon request.
$1150 + Shipping
http://www.us.martinlogan.com/specs/mosaic.html
Frequency Response:
46–20,000 Hz ± 3dB
Sensitivity:
90 dB/2.83 volts/meter
Impedance:
5 ohms nominal
Crossover Frequencies:
450, 3000 Hz
Components:
Air core coils, metal film and low dissipation electrolytic capacitors
High Frequency Driver:
1.5" × 2.25" (3.8 × 5.7 cm) ATF™ Transducer
Midrange Driver:
1.5" × 6" (3.8 × 15.2 cm) ATF™ Transducer
Woofer Type:
8" (20.3cm) high excursion, high rigidity aluminum cone with extended throw drive assembly, non-resonance asymmetrical chamber format; bass reflex
Power Handling:
175 watts per channel
Weight:
30 lbs./channel (13.6 kg)
Dimensions (HxWxD)
40" × 9.44" × 11.69" (102 × 24 × 29.7 cm)
