Front Speaker Choices
  • Thread starter Thread starter WinkyD
Actually, either is on the table as long as I can get it by the wife. She wasn't impressed with the Tektons visually so they're off the table.
There are some really good choices out there with your budget. It definitely pays to do your homework. I have a pair of Sierra 2s from Ascend Acoustics, also with RAAL ribbon tweeters and they're wonderful speakers too.
I stumbled across those for $650 on Craigslist and just had to pull the trigger on them! If I had a choice I'd rather have the upgraded 2EX but for the price I paid for those I can't complain. Long story short I like them so much I sold the speakers I had and bought the matching Sierra towers and center channel from Ascend.
Speaking of the upgraded Sierra 2EX... comes with an upgraded mid/bass driver and crossovers, well within your budget and also very worthy of consideration.
I'm very familiar with the above and absolutely love them, in no small part because of that wonderful tweeter. They're well built and very neutral, accurate, revealing speakers and very close to being on par with the BMR. The nod for bass extension would have go to the BMR, and it's a 3 way speaker with a very interesting midrange, but the Sierra 2EX is right there with it.
One thing that makes the Sierras unique are the bamboo cabinets. Bamboo is stiffer and lighter than mdf and the cabinets are very, very inert. When I do the knuckle tap test it sounds like I'm tapping a solid block of wood.
Those look interesting too.
Hi,
First post in the forum, so I hope I'm not breaking any rules.
I am looking to replace the main speakers in my 2.1 system. The room is about 13 x 26. The home was built in 1910 and the lath & plaster is still in place. The front wall has an open doorway just off-center to the left leading to another room. There is a wood floor covered (mostly) by a thick wool rug from the 1930s and there is a basement. The rug is 9' x 12' so there is about 18" of the floor on either side of it. Placing speakers on the rug also places the left speaker in front of the doorway. This forces me to place speakers to the outside of the rug near the outer walls. I am able to place them out from the front wall about 3'. The listening position is about 11' from the center between the speakers. Thus, the distance between the speakers is wider than the distance to the listening position. Clearly, the speakers must be toed-in.
I have been using stand-mounted speakers and sliding the base of the stands under the rug to move the speakers further away from the side walls. While that is still an option, I am looking seriously at moving to floor-standing speakers. The lower the front speakers reach with authority the lower I can cross over to the sub. This should also help distribute the standing waves in the room somewhat. I listen mostly to music, but I also listen to movies too. I'm not shy with the volume, but I don't play my system for the neighbors across the street either. I prefer low coloration and smooth and accurate frequency response. So, I've been looking at these as potential choices (in no particular order):
  • Paradigm Premier 800F
  • Focal Chora 816
  • Polk Reserve R700
The 800F is near the top of my budget, but I might be willing to squeeze a bit more for something truly exceptional. It might be a reasonable choice based on what I'm reading. The 816 seems to have a prominent midrange and just O.K. bass response. I don't know if pushing up to the 826 would bring any substantial improvements. The R700 appears to have the smoothest response, but the tweeter's dispersion collapses substantially at higher frequencies. I have also read comments that the R700 bass response lack some definition, though it has good extension.
I am open to comments, opinions, and suggestions to break my analysis paralysis. I am open to either floor or stand-mounted speakers for around $2k. Yes, I know I'm unicorn hunting.
I think Focal, Polk, Paradigm, KEF, Monitor Audio, RBH and many others will sound very good.
Talk to your dealers and see if they have any specials or promotions on any of those speakers. Like many things in life, Price could be the deciding factor.
