Huh??? What real world load??? Please explain further
And can do much better if asked to.
Like how?? That dynamic output???
Don't be so presumptuous and shortsighted. How do you know how many watts he needs anyway? You know, one day, maybe he's going to upgrade to something nice like a Totem Dreamcatcher system which dips down below 4 ohms.
And that NAD will drive it properly??? Or, whimper on its shortcomings??
Then all the dynamic headroom is going to be useful. That Denon would choke and die whereas the NAD would still deliver a powerful punch.
Speculation.
The fact is, the NAD will deliver its rated power into complex loads,
Huh? What complex loads? Greatly inductive? Capacitive? Or speakers that are poorly designed as it dips in impedance so much.
But designing an amp to handle complex loads is a much more difficult task requiring a design that provide higher current using beefier components kke larger transformers, output transistors.
What makes a load complex?? Greatly varying impedance loads??
My bet is the the NAD would sound cleaner and play at lower distortion levels with real world music.
Uhm, you would loose big time.
Take two cars.
Why would I want to use a car analogy. Not in the same universe, let alone the same hobby.
Take out your earplugs and actually try *listening* to the components for a change instead of gazing at the spec sheet.
Actually, I listen to music, not components. You should try it
