FREE: Mordaunt-Short 300M Brackets
rnatalli
http://www.mordauntshort.com/summary.php?PID=29
I found a couple of these brackets while doing cleanup and have no use for them. If anyone wants them, PM me your name and address and I'll send them your way. These brackets will fit some other British speakers like Mission.
davidtwotrees
davidtwotrees
No one out there with some MS speakers?
Yep. I owned the whole 500 series 5.0 setup. I sold the fronts and center and still have the 506 dipole surrounds. Maybe you can tell if your brackets would work with my speaks. I have one on a wall and one on a shelf.....so I could use some brackets.......for now and the future.
I did check your link and my speaks weren't listed.....although mine have been out of production for some time.......let me know what you think. TIA.
rnatalli
How far apart are the drill holes on the back of your speakers? I can take a measurement of the brackets' drill holes when I get home tonight.
davidtwotrees
davidtwotrees
I've attached a pic of the back of my MS 506....
I've never used a surround speaker bracket........these were hung up on a screw.. I think these are made to hang on a ball and socket type set up.........I don't have the om and don't think they mention the type of bracket needed. These are hefty speakers........like 15 pounds.......
rnatalli
Doesn't look like the brackets will fit those speakers :(
davidtwotrees
davidtwotrees
Yep. But thanks for trying. I appreciate it. :)
