Well, Susan, (the best side of me and the WAF comptroller in my life), and I got up early and went out to audition the Totem Hawks today. She has never auditioned any speakers, nor given to understanding or belief of what I was talking about when I did. We took along some of her favorite music, (“The Elegance of Pachelbel”), along with my standard reference songs that I have already listed. We went to the B&W dealer first, where understanding what listening to good music on good equipment, was reveled to her and the light of understanding came to her eyes and ears as we reviewed the 685,684,683,704,805,and the 804. I had her rate them all on my sheet. I will come back to this later.
Then we went to listen to some Totems and ended up meeting one of the most hospitable, gracious, knowledgeable persons I have ever had the pleasure of making an acquaintance with. For an old Texas boy that’s saying A LOT!
His name is Don Krasen, owner of Krystal Clear, in Dallas. He has been in business here for 20+ years, so he is the real deal. Well, Don did not have the Totem Hawks in stock but he had the Totem Arro and the Totem Rainmaker. We would have likely auditioned more, but we just could not stop discussing with Don all the intricacies of system applications and the holistic ability of the synergy of the parts which can add up to over 100% of the realization of the end product, if done properly. He never once tried to move us beyond our budget or ruin us for life by letting us listen to something we could not afford. Goggle his name and you will see, he had the power to do so. What an education Susan and I had TOGETHER today!
Now to the Totem Arro. We were totally amazed at the sound that such a small footprint speaker could put out. It uses the Transmission Line enclosure to accomplish this.
Specs are
Break in time: 100 - 150 hours
Placement from rear wall: 6" - 3' / 152 - 914 mm
Placement distance apart: 2' - 12' / 610 - 3 658 mm
Mass Loading: 10 - 20 lb / 4.5 - 9 kg in each cabinet
Frequency Response: 40 Hz - 20 kHz ± 3 dB (with proper room positioning)
Impedance: 4 ohms
Sensitivity: 87 dB
Recommended Power: 20 - 80 W
Crossover frequency: 2.4 kHz, 2nd order Linkwitz-Riley (optimized)
Woofer: 4.5" / 114 mm sandwich cone double magnet”
Tweeter: 1 impregnated textile dome 0.75" / 19 mm (low resonance freq.)
Max SPL's: In average size listening room (12' x 20' / 4 m x 6 m)103 dB peak (12' x 15' / 3 658 x 4 572 mm) from pair at 7' / 2 m
Dimensions (w x h x d): 5.1 x 33.5 x 7.1" / 130 x 850 x 180 mm
We drove both the Arro and Rainmaker speakers in stereo only with an Acram 50w per channel solid-state amp. These little towers would do anyone justice with a small to mid size room without a sub at normal listening levels. When you try to drive them hard, however, we found the highs become too fatiguing. We both felt that they were very forward in sound with a large and definitive sound stage with excellent dynamics. What else can you ask of a speaker of this size? Well, it delivers what you ask in spades and then some for the price point.
I just found out after all these years that Susan, (I gave her the remote and gave her the sweet spot all day), likes to drive it to reference volume! When I asked her why, she told me “It sounds like the performers are right there in front of you!” Guess that says something about my current system, as it has been rare, that she has even listened to any music on it!!
Next the Totem Rainmaker
Specs
Break in time: 70 - 100 hours
Placement from rear wall: 1' - 3' / 305 - 914 mm
Placement distance apart: 4' - 8' / 1 219 - 2 438 mm
Frequency Response: 42 Hz - 20 kHz ± 3 dB
Impedance: 4 ohms minimal
Sensitivity: 87.5 dB/W/m. Maximum sound pressure before dynamic compression
Recommended Power: 30 - 100 W
Crossover frequency: 2.3 kHz, 2nd order
Woofer: 5.5" / 140 mm
Tweeter: 1" / 25 mm aluminum dome, chambered
Dimensions (w x h x d): 6.8 x 14 x 9.1“ / 173 x 355 x 230 mm
Volume: 9 l (internal)
Weight: 5.8 kg (approx. 12 lb)
Recommended stand: TOTEM T4S
We both found this speaker to be a bit colored, but very smooth and responsive, with a pleasing high even at Reference level. More laid back would be the term I believe, without loss of soundstage or spaciousness. We both felt it was a little like a B&W 685 with more extended highs with better decay. Once again, good bass to the point in a small venue no sub would be needed. Just not enough dynamics to suit our preferences. Don apologized for not having the Hawks for us, but explained that the sound would be a happy marriage of the Arro and the Rainmaker. Alas, we still need to find a pair to audition. However, this is a good thing, as we find this to be a fun and enlightening experience to share!
Susan’s take on the day was just like mine. The B&W’s won so far today for what we listened to, not so for what they did great, (because they did nothing great), but for the fact of they did everything good. The others were great in some points but failed in others. Does that make sense? It’s kind of like a win by default.
Now guys, listen up. My Sweetie had a great time today! Why? Because I made sure not to interrupt her and let her ask her own questions. Then, I made sure she always had the sweet spot along with the remote CONTROL. Never was I condescending answering any of her questions in private, and I asked her opinion of everything. Along with that, a fantastic lunch shared, and she got to play with some very expensive equipment, and, Viola!! You have an enthusiastic and understanding partner in your endeavors. Touché!! (The wine at lunch didn’t hurt either!!)
