So I connect from my LD RF AC3 OUTPUT to Demodulator AC3 in and Both from Demodulator Toslink & Coxial OUTPUT to my Yammy Receiver.
YOU KNOW WHAT???????? NO SOUND AT ALL?#@!!
Where do I start to troubleshoot here?
LD Player AC3 Output hardwares?
Coxial Cable for AC3 OUTput?Any special cable to use?
OR the Yammy APD-1 Demodulator gadget?
How can I tell which of theses are causing the problem?
I have more info on this. Since I last posted, I managed to snarf up a RF Demodulator. I got one from ebay, a Sony SDPE800 for around $118. This is a cool unit. You can input several digital sources into it, so I was able to connect a second DVD player via its optical out, along with the laserdisc player. Even though the unit does not specifically decode dts, it allows the dts signal to pass through to my Onkyo digital receiver.
If you truly connected everything where it goes, the only reason I can think that you have no sound (unless the demodulator is defective) is that the laserdisc you are playing is not recorded in Dolby Digital AC-3. You mention having "tons of laserdiscs", but they did not start including AC-3 or dts until the waning days of laserdisc. I only have 10 or so discs that have AC-3 or dts. On mine, I connected the RF out from my Pioneer laserdisc player into the RF in of the Sony with a digital coaxial cable. I then connected the digital optical out from the laserdisc player to the digital optical in of the receiver. Because I have a couple of really old analog sound discs (pre-digital), I also connected the analog sound outputs, or else, that too would have left me with no sound (my Sony unit is really a multi device receiver that includes a RF demodulator, so it has many of the inputs and outputs of traditional receivers).
On my unit, because I can switch between several digital devices, I have the choice of using the AC-3 sound or "Optical". Even though the AC-3 does make use of the optical cable along with the rf out, it also allows me to play "Optical Only", which means it will allow a pass-through of the non-AC-3 signal (or dts) to my digital receiver.
I may be mistaken, but I do not believe the "barebones" RF dmodulators (Kenwood, Pioneer, etc-the ones with only one RF input and one digital input) can do "pass-through" of non-AC-3 sources. I believe that they will only output the signal if it is, in fact, AC-3. If I am correct in this, you will need to unhook from the RF demodulator and hook your digital out directly to your digital receiver whenever you play a non-AC-3 disc. When I was considering such a RF demodulator, I was prepared to do that, but luckily, I found a unit that id more for a good price.
Remember: the disc may say "Digital Sound", or "Dolby Surround", but if it does not say "Dolby Digital" or "Dolby Digital AC-3", then it is not a true Dolby Digital 5.1 disc.
