Focal Aria Evo X No.4 Loudspeaker Review
  • Thread starter Thread starter shadyJ
What do you think of this just released amp.
Will it be adequate for these speakers?
NAD M23 V2
I'd say any of the Hypex modules from their NC/x lines will be able to handle the low impedance, same would go for the Purifi modules. I was recently informed the the MP modules from Hypex wouldn't be recommended for this application. So the NAD should have no issues handling that speaker..
I am deciding between two Focal speakers.
How about using it with the Focal Kanta N°2?
I don't see an issue with the aforementioned amp modules for any of Focal's offerings. Their measurements have no issues with 2 ohm loads. I'm not a huge fan of Focal's design implementations but these amps will do fine. Unless you want to put some extra money into a couple of AB amps on the market, you will be fine with the NC/X or Purifi nodules.
