I am looking to clean up the TV area. I would like to put all the components and wiring in the wall next to the TV. Any help I could get would be great. Example pics would be great.
Most walls are not deep enough to take equipment. If you flush mount to a wall you need a walk in mechanical space behind or it is a nightmare.
There are in wall speakers, but for the center you need to match your left and rights. You can only put a speaker in a wall that is designed for that location.
Is this something like the effect you want?
If it is you need this. Otherwise you will create a nightmare.
Then you need to do something like this for your center.
And mount it like this.
Is this the type of final effect you want?
