Fluance Ri71 Powered Bookshelf Loudspeaker Review
  • Thread starter Thread starter shadyJ
shadyJ
Speaker of the House
Staff member
Is it possible that soundbars are losing popularity? More and more loudspeaker manufacturers seem to be releasing traditional loudspeaker designs that have HDMI ARC connectivity. I don’t have the sales figures in front of me, but I don’t think that the explosion in active loudspeakers with HDMI connectivity would occur unless there was a demand for them. That could only come at the cost of soundbars. Perhaps buyers are realizing that they can do better than the inherently compromised sound that soundbars produce. Whatever the cause, I welcome the new trend. Better sound can be had, but how much better? That is what we will be looking at in today’s review of the new Fluance Ri71 powered bluetooth bookshelf speaker review. Read on to see what we thought of these speakers...
READ: Fluance Ri71 Powered Bookshelf Loudspeaker Review
I haven't heard the name Fluance in a long time it seems like. Good for them.
This is a step in the right direction. To leave out the grill was a bad mistake and limit sales. It excludes families with young children and many to not like looking at loudspeaker cones. I know my wife would not tolerate that. They would be a huge temptation to the great grandchildren
Two of the most absurd products in the history of audio and AV, has been the AV receiver and the Atmos Soundbar.
Since Atmos and the addition of those channels, the space for power amps has got further squeezed and now only one channel driven can produce full power. This makes the design of the power supplies and power amps increasingly problematic. There is only one way to describe it and that is; - Bad design and engineering. Just because it is familiar and ubiquitous does not make it right, and close examination shows it to be severely compromised.
The right, and intelligent place to put the amps is the speakers.
This allows for the amp/amps to be designed and sized for the speaker it is driving and an end to this one and all channels driven power specs. The fact there is such a spec. just advertises what a lunatic approach it is.
Then we get to sound bars which are only marginally better then the TV speakers due to the size of the drivers.
So with eARC a decent pair of speakers like these and the possible addition of a sub, gets you a really nice affordable system. It can play the TV sound, and TVs these days have streaming function and HDMI inputs to connect items like disc players.
Better still one only buy the amps you actually need. You can add speakers as required, starting to add a powered center if you want and then add other speakers if you want, assuming the room is suitable and frankly most are not.
This can lead us back to a time were many more homes will have good audio, which could easily become the majority, rather than the few.
If I were the Harmon CEO, my first edict would be to decree a date certain the end AVR production and passive speaker production.
Now let the screaming begin. Change for many is frequently difficult to accept as rigid thinking is prevalent, but a curse on humanity nevertheless.
James thanks for the review. Good to see you back with a review it’s been awhile. Always good to see reviews of affordable equipment that sounds good.
For active speakers, you preferably need AC outlets close to each speaker. That means if you don't have close AC outlets, you then end up with line cords running around instead of speaker wires. This isn't much of an improvement over typical external power amps.
It is because you don't have this 2 speakers driven nonsense of AVR. Although the reviewed speakers are powered with a passive crossover, speakers with active crossovers rather than passive crossovers should give significantly improved performance. Most homes these days have lots of AC outlets and in any case AC outlets can usually be easily added and installed.
Don't understand your 2 speakers driven comment. My home definitely lacks outlets for multiple active speakers' locations and it is not even remotely interesting to tear the walls apart to accommodate.
Denon on even their high priced receivers are have specs showing the power of 1 channel driven higher than the two channel driven and not even daring to spec. all channels driven. AVRs, never a good idea, are reaching the absurd.
Subs are active and need to be plugged into an AC outlet and many seem to throw four and sometimes more subs about their rooms. So what is the difference?
I have several diy passive subs, so don't need outlets near them.....
I haven't seen such specs on my various Denons, they're all basically 2ch like the competition and rules mostly dictate. ACD ratings aren't particularly meaningful in any case.
One or two channel driven power ratings are irrelevant for most people in average listening room sizes, and it's obviously the situation with someone who has sensitive speakers.
