i'm still considering both, build from scratch and buy ready to build kit. but looks that the second idea fit better for me
i can have that sony for 50$, is really cheap for me now. i have to pay 24% on every things it comes outside my island. for the beginning, it works if the amplifier take just the optical audio from pc and bluray after i can consider a better one
don't worry, sometimes i'm not even sure on what i'm going to do
part express have:
- c-note
https://www.parts-express.com/c-note-mt-bookshelf-speaker-kit-pair-with-knock-down-cabinets--300-7140
but only MT bookshelf, and no mtm center for thi series
- avitrix (my favorite)
https://www.parts-express.com/Search.aspx?keyword=avitrix&sitesearch=true
can i use the mtm vertical on the surround front in vertical and the center channel horizontal ?
the idea was mtm in the 3 front channel and mt in the back
-overnight
https://www.parts-express.com/Search.aspx?keyword=overnight&sitesearch=true
just the mt solution, no mtm for the center
-tritrix
https://www.parts-express.com/Search.aspx?keyword=tritrix&sitesearch=true
as avitrix, mtm on the front and mt on the back
so, can i use the mtm vertical and horizontal on the front?
i have understand that the center channel is the most important and used in home theater configuration, and is the way i will use more than other my system
i get the opportunity to read the loud speaker cookbook, looks really professional and i dont think to understand a 50% on what there is inside right now, so just diy kit for the moment
i will check later diy sound groups
