Firmware on the 2910
boe
I went to Denon's website to check for a firmware update for my 2910. When I put in the SN it says there is none available. The Denon rep at CES said a new one was just released
Can someone tell me how I tell what firmware I have (I think each denon model is different)
What is the current firmware
Thanks
boe
Got it - turn off the power with the little button
Hold down play and open
Wait 3 seconds
then press 3265
menu
Mine is version 5 - the current version according to Denon
boe
Kenny the sales weasel
The rep I spoke to at CES claimed Denon released a macroblocking fix for the 2910. The latest firmware release for the 2910 is still November's version 5. The 2910 is a great unit but still suffers the macroblocking issue.
Pete Dzwonkas
What exactly is macroblocking and what do you see when it occurs?
boe
It is kind of like defective pixels on a LCD laptop screen only bigger and not permanent. It is little segments that don't match the rest of the scene. I read a few descriptions of what it is when I searched for it but I didn't see any that I am sure are the definitive explanation. Perhaps an AV engineer might explain better than I can.
aarond
is the macroblocking noticeable on your display?
because it doesn't effect all display's
there most likely will never be a firmware update to fix it since it is a problem with the Geneis FLI chip
it was a problem on the 5900 and Denon has made improvements so it is not as bad as it was.
no dvd player is going to be perfect
