Ok, I am trying to set up a audio system for my firehouse that will cost more/less than 600 dollars. Here is the system I would like to use.
amazon.com/Pyle-Studio-Package-Concert-Performance/dp/B0085DZUOK
My question is, can I use all 12 speakers at the same time? Will the amp and speaker selector be able to handle it? I do not need it to be incredibly loud, just loud enough so you can hear the firehouse scanner.
Thank you, Matt
