Finally Made My Decision, Went With The Denon AVR 2808CI - THANKS!!!
Pipelayer
Pipelayer
After taking in all your advice and help and contributions I've decided to go with the Denon AVR-2808CI !!! Thank you very much for all your input, I am extremely happy with the decision you help me come to. :D
Denon AVR-2808CI - $814.00
Features and Specs:
New front panel design, controls and lettering
Equal power amplifiers: 7-channel
Power output (watts per channel @ 8 ohms, 20hz to 20kHz): 110
All channels rated @ 0.05 THD
7.1 Pre-outs
Low impedance drive capability
High-current/discrete amplifiers
Independent power transformers: 2
DSP Processors - Analog Devices, SHARC: ADSP 21366 x 1, 21367 x 1
Processor design: 32-bit floating point
Processor circuit sampling frequency: 192kHz
Dolby TrueHD and Dolby Digital+ Decoding, dts-HD Master Audio Decoding
THX Surround EX and Dolby Digital Surround EX decoding
Dolby Pro Logic IIx, with Cinema, Music and Game modes
dts ES Discrete 6.1 and dts ES Matrix 6.1 decoding
dts Neo:6 Stereo-to-Surround Cinema and Music modes
dts 96/24 5.1 for DVD-Video processing
XM-HD 5.1 via Neural Surround decoding
Compressed Audio Restorer for portables/iPods/network audio
Audyssey MultiEQ XT auto setup calibration and room correction for 6 seating
positions
Auto setup microphone included: New Y/Mold type
AL24+ Processing on front left and right channels
24-bit/192kHz DACs: DSD1608
Analog-to-Digital conversion: 24/192 PCM1804
Variable High/Low Pass crossover points (12/24dB):
40/60/80/100/120/150/200/250
Assignable digital inputs
iPod ready with a Denon D-dock
USB Port for portable music players/flash drives/HDD with command and
control functionality
XM Satellite Radio ready - "Mini-Tuner" compatible
Multi-source/Zone discrete tuner select function - AM/FM/XM
HDMI 1.3a Repeater Inputs/Outputs - supports 1080p, 36-bit Deep Color, xvYCC
Color Space, Auto Lip Sync correction, 7.1 uncompressed 24/96 Audio, SACD
Analog to HDMI Video Conversion/Scaling: 480p/720p/1080i/1080p
Faroudja DCDi Video Processing and Scaling (FLI02310)
Main Zone Video Encoder: Analog Devices ADV7320 12-bit
Main Zone Video Decoder: Analog Devices ADV7403 12-bit
NSV - Noise Shaped Video processing
Digital Inputs: 3 coaxial, 4 optical
Digital Outputs: 2 optical (assignable)
Digital-to-Analog REC Out
Analog Audio Inputs (including Tuner): 10
Phono Input
Analog Record Outputs: 3
Front Panel A/V Inputs w/Cover: Composite, S-Video and Optical
Independent Video Conversion: S-Video to Composite for Zone 2
Composite Video Inputs: 7
Composite Video Outputs: 3
S-Video Inputs: 7
S-Video Outputs: 3
Component Video Inputs x bandwidth (assignable): 3 x 100
Component Video Outputs (parallel main zone): 2
Discrete second zone Component Video Outputs
RS-232 Port for third-party controllers and new Denon 2-way Remote Control
and RF/IR Base Station
3-source, 3-zone capability
D/A conversion for multi-zone outputs (Optical, Coaxial and PCM signal only)
Enhanced Power Amplifier assign for multi-zone or bi-amping: 4 modes
Compatible with optional RC-7000/7001CI IR/RF 2-way Remote/Base Station
Dimensions (W x H x D in inches): 17.1 x 6.7 x 16.9
Weight: 30.9 lbs.
Bluesmoke
Is that $814 shipped? From an authorized dealer?
Pipelayer
Pipelayer
1.) $814 shipped - Yes (Free Shipping)
2.) Authorized dealer - No
Got a 2 year Mack Warranty (cheap) - Nevertheless, have friends that have registered their system with Denon as a gift (having no receipt of place of purchase) and have recieved warranty service with no problem (I plan to do the same). If you are a Denon owner you will also notice that on the on-line registration form it is not a requirement to fill of the name of the retailor from which the amp was purchased, that is because of the gift factor. No company would want to discourage people from buying their products as gifts, since that generally counts for a large number of sales for most popular and well known companies.
