Family room speakers
Jay
I have finished my home theater area in the basement using Axiom 60, 150, QS8 and an SVS sub. I love the setup and am happy with the speakers.
My next project is the first floor family room. Currently, all I have is a TV. Since we entertain and don't always want to be in the basement theater, I am looking for speakers for the family room. My room is 17X22 and opens to the kitchen behind the seating area (another 14X16). The speakers will be placed next to the TV and the sound will travel through the seating area to the kitchen. Therefore, the sound will travel 38 feet before hitting the back wall. The ceiling is 8 feet. The speakers will be used for only music and I am not looking to put in a 5.1 system in this room.
I was looking at the Axiom M22's but not sure if they can fill the room. I also don't have to stay with Axiom. Also, should I get a sub to go the the system? I would like to stay around 1K max for the two speakers and even less would be great. Thanks.
Z
zumbo
Filling the room with sound is going to be more of a power issue using two bookshelf speakers.
Are floorstanders out of the question? While there are bookshelves that come close to covering the entire frequency range, a set of floorstanders would do a better job in the under 1k range.
Another option is bookshelves with a sub, as you mentioned. As long as you have the room for the sub, this would be a good option as well. However, if the source is a stereo receiver, I still say go with floorstanders.
Jay
Thanks Zumbo. Everything you mention is OK. Floorstanders or bookshelves with sub. I don't have anything to power it as of yet so I am open for options with this as well. Please let me know your thoughts.
Z
zumbo
Well, if the system is to be 2-channel only, you can save using a stereo receiver. If you don't want a radio tuner, you could use an integrated amp. All depends on what you want.
Is the 1k for speakers only?
Jay
1K is for speakers only. However, I am flexible and can bump it a few more hundred if need be. When I say it is only going to be two channel, I may be play some DVD music concerts or DVD-A discs that are in 5.1 but will only be through the two speakers. I just don't want to be bothered with a full setup in the family room since I have one in the theater.
Z
zumbo
Well, you need an AV receiver. That's good. Now we are open to the bookshelf and sub set-up for sure.
Z
zumbo
Saturday Audio has the Monitor Audio S2 bookshelf speakers for $449.00 a pair. They are of the highest quality you can get for that price. I will post the link. Click on new gear on the left. Then, click on speakers in the middle. Scroll down to Monitor Audio S2's. Click for sale price. They will be out of these jewels soon. They only have the beech color left.
http://saturdayaudio.com/
Add an HSU sub, and you have one killer set-up.
http://www.hsuresearch.com/products/vtf-3.html
N
Nick250
That 1k budget offers you so many choices, wow. I suggest you audition locally as many as you can in concert with ID route. Getting a tower vs a book shelf speakers with a sub will make know when you are auditioning and probably depend on each speaker system you choose.
I demoed the the B&W 602s recently, and for $600 I loved the sounded. There was no sub in the configuration I was listening to, so I will offer the 600 series B&Ws and Paradigm (I own the Studio 20s) for consideration.
Good luck!
Nick
Jay
Thanks, however, I don't like the beech color. Our furniture is darker wood so I think a dark cherry, mocha or black would be better.
One question, why are those better than the floorstanding series for about the same price.
Z
zumbo
A bookshelf/sub combo works better because the sub is powered. Since it has it's own amp, all the receiver will be powering is the bookshelves. The woofers in a large floorstander will hog the power from the receiver.
Z
zumbo
Also, you can usually get a higher quality bookshelf vs a floorstander for a certain $ amount.
Z
zumbo
While I do like the B&W 602 option, I believe the Polk Audio RTi 8's sound better for the money. This will put you a little over budget, with the sub I recommended, but they are truly a good sounding set of speakers. They are not full range, so a sub is still needed.
http://www.onecall.com/ProductDetails.aspx?id=28507
mouettus
mouettus
No Sub!!!
Hey whatever you choose... don't go with a sub. 2-channel music is WAY more enjoyable only with a good pair of full-range speakers. With 1k$... you can go a long way. At that price point, I auditioned Energy Conoisseur (which you don't have in the US I think). But the point was that the speaker was built with a tweeter, a mid-sized woofer (5¼") and two woofers (6'). In terms of bass, you could almost go as low as you want. You won't get the power and the extremely low frequencies at high level but you can certainly feel the oomph on bass drum or hear the full potential of bass notes.
In terms of amplifiers, I REALLY recommend NAD for music. Something around 100 cwpc should fill your area quite well.
btw, don't even bother auditioning rti8's for music, they sound awful (I own them)(Really good for movies). The Rti10's are very different though... giving you the woofer setup I speaked about
Z
zumbo
6" woofers can go almost as low as a sub? Are you out of your mind?
RTi 8's sound superb with music. You must have a power/set-up/placement/room issue.
I use my sub for 2-channel listening, and my speakers smoke RTi 8's.
Z
zumbo
Never-mind. I see it in your sig. A $300 receiver is not going to even get the RTi8's going. Also, they don't do well in the lower-end. This is why a sub is needed. They absolutely sing crossed-over @60Hz.
Jay
OK. I like the look of the polks. How do they differ from the Energy bookshelf you provided? I like the HSU subs. Almost bought one for my theater but went SVS instead. I know they are better musically so I am fine with the purchase of one for this setup since it will be for music.
Now what about amp? I am open to anything, say $500 or less for an amp budget or should I go higher.
Z
zumbo
I would say Energy has an edge on Polk in general. But, IMO, the RTi8's are a better move here.
Best deal around on a receiver.
http://www.onecall.com/ProductDetails.aspx?id=29695
Jay
I have a Yamaha 2500 in my theater. Is this better than that? If so, I could switch them out. Or, would another last year model work as well. For music, I am not sure I need all those bells and whistles which is why I am thinking an older model will do. What do you think?
