Extra subwoofer channel needed
Truett
I have a Trinnov Altitude 32 with 12 subwoofers. I am one channel short. I can always double up 2 subwoofers on 1 channel. But is there a way to further split a channel using a separate MiniDSP or something so that I can calibrate each sub separately?
WaynePflughaupt
WaynePflughaupt
Yes, you could use a miniDSP to functionally split the signal and separately process two subwoofers.
Regards,
Wayne A. Pflughaupt
Truett
Regards,
Wayne A. Pflughaupt
I am not familiar with buying MiniDSP. Is there a particular model that does what I need here?
WaynePflughaupt
WaynePflughaupt
Maybe someone who’s familiar with their product line will chime in. But basically, you want one that has (for example) one input, and at leastwo outputs. You can peruse their model lineup, thn you can study the manuals and see of both outputs can be processed independently.
Regards,
Wayne A. Pflughaupt
