sloal said:
I'll be buying a Sony 50" SXRD, and already own a Yamaha HTR-5760 receiver.
I'm not enought of an audiophile and do not want to go through the wiring needed for a 5.1 system and was thinking either about going stereo or maybe creating a 3.1, except that no one thinks 3.1 is anykind of an answer, and then someone said why not go 5.1 and just put the "rear" speakers in front, but to the far-far right and far-far left.
Does this make any sense or should I just go stereo or is anyone doing 3.1 or maybe just 3.0
thanks for your help.
a
sloal: Try this.
Set up the battle scene in Gladiator where the catapults are cocked, loaded and twinging behind you (with the rear channel in dts), are then viciously slung into movement with the shell screaming past your head (now at the side channel), and ends up tearing a hole in a defender, and then knocking down a tree, crackling and scraping (through the fronts, center and sub, which has been pounding the entire time).
Else, try one of the battle scenes in The Patriot, where you feel like ducking your head because a cannonball, that you just heard behind yourself, now flies past your head, and then rolls away from you.
There are countless other examples of extraordinary channel separation, in both dd and dts (my favorite), that you will
never experience in 2.0, 2.1, 3.1, 4.0, etc.
If, after you've experienced true surround sound you still "do not want to go through the wiring needed for a 5.1 system", then at that point you have made an informed decision, and at least you know all of what you'll be missing the next time time you watch a movie in anything less than 5.1.
