Chris,
> Your graph does not prove that null of equal magnitude to a peak of X frequency, Y gain and Z bandwidth is more audible than peak of X frequency, Y gain and Z bandwidth. <
You are correct. My graph merely shows that all rooms have severe nulls, and common sense then dictates that a severe null will be audible if it aligns with a frequency in the music. Do we agree so far?
> Where is the correlary perceptual research? <
I do this stuff every day, all day long. You can claim it's ancedotal, and perhaps it is, but please don't lump what I'm saying with voodoo and snake oil like green magic markers!
But that doesn't make it speculation either because I observe this all the time. The most common problem people have when mixing music in a home studio is deep nulls that make them hear less bass than is really on the track, so their mixes suffer from too much bass. The second most common problem is the opposite: they're sitting in a zone having one or more big bass peaks, so their mixes come out too thin sounding. Are we still in agreement?
> (cable sonics, high resolution audio, immeasurable sound properties of exotic amplifiers, green cd markers, etc.). <
It's clear to me that you and I agree a lot more than disagree, generally speaking!
> If the dip in response is minimum phase, then it can be countered <
Bingo - this is the exact problem. There are so many different reflections in all rooms, all coming from different directions and with different delay times, that no one null can be attributed to a single "filter" pole. So by extension, EQ cannot do much to reduce the ringing because the countering needed is so complex. Perhaps some of the more sophisticated DSP systems could do a better job than a simple parametric EQ, given enough CPU horsepower. But then the problem is that the correction becomes highly localized. Moving even an inch or two - equal to turning your head a little - will cancel the improvement, and surely make the response and ringing much worse.
> Please show me where on my graphs the EQ caused ringing. If you mean your graphs, the low bass was significantly cleaned up with equalization <
Yes, I mean my graphs, and "cleaned up" - however you care to define that - still does not discount the large ringing that EQ added around 92 Hz.
> Which perceptual reference research that you use to coorelate the measured data with audibility? <
Well, I walk into a room and it has huge audible nulls that make the bass all but dissapear. I add a bunch of bass traps and, voila, the bass is nice and round and full again. This happens every time without fail.
--Ethan
