UPA-1 Specifications:
* Number of Channels: 1
* Amplifier Gain: 32db
* Signal to Noise Ratio:
1 watt: >89db
Full Power: >117db
* Input Impedance:
Unbalanced – 23.5kohms
Balanced – 33kohms
* Transformer Size: 300VA
* Output Devices: 6
* Topology: Fully Discrete, Dual Differential, High Current, Short Signal Path Class A/B
* Power output (all channels driven):
350 watts RMS @ 4 ohm (0.1% THD)
200 watts RMS @ 8 ohm (0.1% THD)
* Power Band Response: 20 Hz to 20 kHz with less than .05db deviation at rated power
* Broadband Frequency Response (-3db): 5Hz to 150kHz
* Secondary capacitance: 80,000uF
* Size:
Unboxed: 17" wide x 3.875" high x 18" deep
Boxed: 22.25" wide x 8.5" high x 22.25" deep
* Weight: 26 lbs (35 lbs boxed)
