Will a pioneer vsx-1019ah-k drive E55Tis?
I have been doing a lot of reading to find out which tower speakers to get to start replace the front channels of my Harman Kardan HKTS-14 system. Based on how the E5s were received, it seems like the E55Tis would be a significant step up. I also want to replace the center channel soon.
However, I am concerned that my pioneer vsx-1019ah-k is ill-equipped to handle such efficient speakers--the manual says it can handle 6 ohm speakers but a setting change is required. If it isn't up to the job, am I out of options with this receiver? There is a preamp out for the sub only, so I don't think I can use an external amp.
On a side note, any thoughts on how the E55Tis would work with the 12" sub that came with the HKTS-12?
I know my setup is pretty amateurish, but I want to make better buying choices going forward. I appreciate any advice. Thanks.
