Hi guys,
As you can see with my gears, the problem I'm encountering is the bass management - it is fixed at 90
. Which I think doesn't caliberate with my speakers).
So I'm leaning towards Emotiva LPA/LMC package. I have some questions regarding this system:
1. Is it possible for me to set the cross over points: 50 mains, 70 or 80 centre and 90 or 100 rears.
2. Since it is separates: do I have to adjust the LFE level, if so, can LMC handle this.
3. I don't listen to 2 channel, I use PL11 Music for audio CD. DVD in DTS. These are the only use in my system. I don't have any other set-ups.....primitive indeed
Does LMC has bugs in these settings. Because these are very basic set-ups, if there are any bugs, I will be really disappointed.
4. I'm not a loud listner, my system is almost 6 years now, never reached to, at least half of the loudness. So is the Emotiva package worth the investment when considering my habits & constraints of my current system.
My mains specs: 4-8 Ohms, sensitivity 90, range 35-20
Centre: 4-8 Ohms, sensitivity 90, range 60-20
Rears: not sure
Thanks guys.
