Looking for a new receiver? Here is what our friends from Emotiva Audio have in store for you.
The Emotiva Fusion 8100 is the all-in-one solution that does it all. It features a powerful class A/B amplifier, featuring 7 x 65-watt RMS of audiophile caliber power, all channels driven, backed by an oversized toroidal power supply, puts real punch into movie action. But its powerful amp is just the start. Full compatibility with all high-res surround sound formats, precision quad core 32-bit processing power, the precise control of 11-band fully parametric EQ’s, and flexible bass management featuring selectable crossover slopes. It also includes Emotiva's exclusive one-button Fusion Advance Room Correction System™, for the ultimate in convenience and performance. And the best of all is that you can get all that and more at a price you can afford. Plus, its standard 3-year transferrable warranty beats the competition by up to 3x. Wow!!!!!!
Wondering about the specs? Here you go!
- 4 – HDMI 1.4 inputs with 3D and CEC support.
- 1 – HDMI 1.4 output with ARC4 – Line inputs (unbalanced, stereo).
- 1 – 7.1 channel unbalanced input (7 channels plus sub).
- 1 – 7.1 channel unbalanced preamp output.
- 1 – Balanced subwoofer output.
- 1 – Integrated Bluetooth receiver.
- 2 – Zone audio outputs (unbalanced, stereo).
- 1 – Audio out (mix out, unbalanced, stereo).
- 4 – Digital audio inputs (2 - optical Toslink; 2 - coax).
- 1 – USB input (for firmware upgrade only).
- 2 – Antenna inputs, AM and FM.
- 1 – Trigger input.
- 1 – Trigger output.
- 1 – IR remote input.
- 1 – IR remote output.
- 1 – RS-232 serial control input.
- 1 – Subwoofer output (line level XLR balanced).
- 7 – Speaker outputs (4 ohms / 8 ohms) gold plated 5-way binding post.
- 1 – Remote control with CEC control panel.
- 65 watts RMS x 7 channels; <.05 THD (all channels driven).
- 110 watts RMS x 2 channels; <.05 THD.
- Size (Boxed): 22" wide x 8.5" high x 21" deep.
- Size (Unboxed): 17" wide x 4" high x 16.5" deep.
- Weight: 25 lbs. (34 lbs. boxed)
Price: $499.00
