I had everything listed below plugged into a single 15A outlet.
As well as a 37" CRT, dvd player, and a VCR. All on at the same time.
My 2 amps combined pull about 1500 watts RMS @ 4ohms
If I had my stereo cranked 95-100 db+ (not normal listening levels) with all the components on, the lights would slightly dim to the music. If I tried to turn everything on at once, everything would start, except for the CRT.
If you got a bunch of amps, the initial power draw from turning everything on at once would probably be a problem. A power sequencer would take care of that. Check out Furman Sound.
Correct me if I am wrong, but I didnt think that amps continuesly pulled the max amperage from the outlet if you were only using a smaller percentage of power.
For example (these calculations are made up): Lets say a amp is rated at 1000 watts per channel, for 7 channels, that'd translate to 14 amps. if you only have it at 1/2 volume, really only using 500 watts per channel, you'd pull 7 amps from the outlet. As the volume increases, the demand for more amperage increases.
