DVI to RCA (yellow)??
crazydog
Hey..
I have a PNY GeForce 6600 GT with a DVI output.
It came with a HDTV splitter, which I lost, but that isn't importent since I do not have an HDTV.
My question is: Is there a cable or an adapter that will let me plug it into the DVI port, and the other end to a standard RCA video plug (the yellow one).
Fast responce appriciated!
Edit: By the way, I also have a DVI to VGA adapter, so if there is a VGA to RCA Video that would work too.
OR I have a 9 pin S-Video out in the card, but no S-Video plug in my TV. Any S Video to RCA video cables?
t3031999
Of those, and S-video to RCA is going to be your cheapest bet.
Here is a cheap adapter. You would just have to by that and a composite video cable.
crazydog
it has a 9 pin S-Video plug
3 on the bottom, 4 in the middle, 2 on the top
the one you showed me only has 8
t3031999
That extra pin isn't used when it is transmitting composite video, So that one should work just fine unless your video card has a proprietary s-video implementation
