thanks,i really had tried everything i could to get it to work before i asked the question,i was really just trying to figure out why it wouldnt work,the manual that came with the tv was on a disc and i couldnt load it to my computer,i had seen and been through most of the options on the tv,just didnt know what some of them meant,thx to you i know what one of them is now,sry if i was misleading you into thinkin i was relying on you for info,now im glad you did,and thx for the info you gave...
im thinking since the lg player and tv link up when you watch something on it ,that since its a blu player it wont play anything at 24 but blu rays,thats just what im thinking,and i asked my buddy to play a dvd on his blu player and he couldnt get it to run at 24hz either....but thanks for your time and info...
Sure thing. If you want to output DVDs at 24p, and you're certain that yours cannot, you ought to look at certain Panasonic players (they've been able to do this for years now); they're what I recommend 9/10 times anyway, regardless of that feature.
HOWEVER- it appears that you need to set the 24p function on the Pana,
EVERY TIME (as I somewhat referred to in on of my other post in this thread, going by iffy memory).
If I understand things correctly, the reason being is that there isn't a "metadata standard", and I don't think the player will know when it's the proper time to "extract 24p" or not! If it always tried to "extract 24p", it will still try to do so, even for stuff that was never encoded that way to begin with! The result? A horrible pic!
The other option, maybe easier and maybe not, but probably way more expensive, is using a BDP that has a "source direct" option, where DVD is always sent as 480i (no extraction), BDs as whatever it's (truly) encoded with, and using a video processor to handle, well, your video processing ($$$$).
If you really care about this, I'd just get the Pana player.
But really- I'd personally get a different TV firstly, in all likelihood.
If you got the $$$, anything can be solved.
I wouldn't worry about it, if I were you.
I should give out a begrudged thanks to mtrycrafts for forcing me to learn more about this subject.
