DVD Player Direct to Computer Monitor
Mudcat
Mudcat
Here's the problem.
Often at work we get DVDs from contractors. These often contain movies of a ship design. When we get these, we (I) need to go off to conference room to view it.
Now the situation.
Now we just got these great looking Samsung Syncmaster 910T monitors. The monitor has both the standard VGA input and a DVI-D input. I would like to get a cheap DVD player to sit here on my desk to play these contractor provided DVDs. Do I need to get one of those converters like this:
http://www.ramelectronics.net/html/kd-ctca2.htm
or can I just get by with an adapter cable like this:
http://www.ramelectronics.net/html/hdtv-cables.html#hd15rgb
Since this is work, and I won't be able to watch movies (honestly - really) I would like to do this as cheaply as possible. I realize I can get a DVD player with HDMI output and get a cable that will go from HDMI to DVI-D and spend less than $200 (player and cable), whereas the component to VGA could cost upwards of $350 (player, converter, and cable), while the cheapest option - as little as $50 would be a player and component to VGA cable.
I've checked all the threads and other material here at AH to no avail, now I need input from you guys. PS - Samsung was totally useless on this matter.
PSS - I do plan on using said system to listen to CD via Sennheiser HD650 cans powered by a Chinese tube amp (someone left it behind when they moved on to greener pastures - says alot about this amp, doesn't it.)
BMXTRIX
BMXTRIX
I would ask first... Isn't your computer monitor hooked up to say... a computer?
Aren't DVD drives for computers like 20 bucks these days?
That would be the least expensive, and best way to go. Most DVD players are optimized for video display output, not computer monitors. That is why most people consider the Home Theater PC (HTPC) to be the best way to watch a DVD, because you can match the output of the computer to the resolution of the display.
Mudcat
Mudcat
Right you are. But, this is the youass govt we are talking about. Nobody here has a computer with a DVD player, only three have a CD burner, and there are still some people using Pentium 60s in this building. Nuff said on that subject.
