Z
Zarg
So, what lens cleaner do you recommend? How often do you clean your DVD?
Thanks!
Mr.T
Actually your best bet is to keep your DVDs clean, so you don't have to clean the lens that much. Every 3 months if you're using your DVD player a lot and every six months for a normal usage.
This lens cleaner seems to be one of the better ones, it costs a little more in comparison to the others, but it does a visible better job.
Service techs obviously use different methods because they take the unit a part to get to the lens and clean it with a liquid cleanser and a lint free cloth.
http://www.shopping.com/xPO-Maxell_Lens_Cleaner_with_System_Check~CLT-HSNLF
Thanks!
Do you have tracking problems now?
Lens cleaning mostly are not needed for a very long time, except, maybe, in extreme conditions in which you would probably not live in the first place :)
