So after 16 years all my dust caps got pushed in by my friends 3 yr old this weekend. I tried every solution on the internet and did finally get them popped out....however the only way I got them done was to use a pin. So now I have a few small holes in the caps. 2 of them tore very slightly maybe 1/8" of an inch. I have researched all options. Right now I am leaning toward nail polish and just paint a thin layer over the caps and fill the holes....
Any better ideas....
The drivers in the speakers are all out of production and i can not buy any replacements. Not ready to buy new speakers quite yet....
I have listened to them with the holes and I can not tell a sound difference on a quick check, but am concerned if I don't fill the holes it may get worse....
Thanks
Jeff
