Dude, SPL is not going to be an issue, lol! Yes, keep the phase the same until your measurements tell you to change it. What you need to do is put on your critical listening ears and a familiar musical bass/drum riff and ensure both subs are playing in unison. If the beat of the music is not tight, you need to turn your head or stand up and figure out which sub is playing first, and then keep adding a millisecond delay to that sub until they both 'play in time'.
And before you ask, length of the cables is not the only cause for concern about setting the delay. The other issue is the control the room has over the distribution of high pressure areas in the room. Yes this can be influenced with where you place the subs, but the length of time it takes to propagate large wavelengths that are audible at a specific place in the room varies a lot more than people seem to realize!
Good luck!
