Down-firing on carpet? Does it matter?
  • Thread starter Thread starter KASR
In my case with Mirage's down-firing ports, there's plenty of clearance between the S12 and the carpet, and the S10 and the top of the S12.
Or course, all I have to do is turn the gain control on the 12 all the way down and just listen to the 10, and see what it sounds like on it's own.
Jack, I am glad you made sure to check the clearance so that there is enough room for the ports. Sounds like you have things coming together. I am glad it has worked out for you. ;);)
Cheers,
Phil
^ first post and picks a 12 year old Thread :oops:
With carpet cleaner links SMH
