Dont Laugh Help Needed
jrwolfman1
Hopefully this thread is in the correct forum.
I am fairly new to the AV world and have started to make some improvements to my man cave.
I have an Infocus LP70 Projector, Sony DVD Surround Sound System (cheap but it works for my space), WII Game Console.
Prior to connecting my game console to it I had no issues with the horizontal roll displayed on my screen. Also the same time I was connecting my WII the projector fell and it took a small piece out of the plastic casing.
After connecting my Wii and Arista AV switch I started getting the horizontal roll on the screen. It didnt matter game or movie same results.
Today after deciding to get into the problem I discovered the "ground loop" concept. After disconnecting and reconnecting everything I pretty much am set that the AV switch is creating the roll.
With the DVD Surroud connected straight to the projector I get no interference.
So with that being said what AV switch will be my best option at an affordable cost ($200 or less)? I would also like the switch to have a coax connector so I can plug my coax from a cable splitter to watch TV with the projector.
I have read some forums that indicated Joytechs but I cannot find them anywhere and the threads I have read are old 2002-2007 and nothing after.
I may not have a $10000 system but being Army retired its the best I can afford.
Any and all help will be greatly appreciated.
TIA
caper26
caper26
diconnect your cable for your TV and see if the horizontal roll goes away. When I bought my 47" LG, I thought the TV was defected because of the faded black bars scrolling up and down...turned everything off and even unplugged everything else and they were still there...I only found out by accident when I tried to move my cable box and it wouldnt reach, and I disconnected the COAX cable and voila...it was gone.
