Yes, I've read those evaluation white papers, interesting.
I've had some probs with the neighbors about the loudness of my sub, so we found an acceptable level when playing DD tracks on DVD's. Later I wanted to play the DTS track of 'The Day After tomorrow', so I played a part that had a simple moderate volume bass tone with virtually no higher Frequency information as a comparison for the two tracks. I then set the receiver to my normal listening volume and with my SPL meter in hand(set to show the MAX SPL(since this is what I wanted to limit)) I switched between the DD and DTS tracks and adjusted the DTS Sub-woofer trim(this only effects the subs volume for DTS encoded tracks and does not effect main volumes for other formats including DD) to bring the LFE of the DTS track in-line with the DD tracks volume.
What I ended up with was the DTS sub volume trimmed -7.0 (compared to the DD at 0.0). And even with the DTS sub down by 7.0 the SPL reading showed it was 2-3db louder than the DD track.
This little exercise showed me that DTS tracks are mixed louder than their DD counterparts,
as everyone knows louder sounds better even if its not better, even the Dialog Norm feature cannot explain such a difference in volume as for that DVD the DD track had a -4 Diag Norm factor, and I had the DTS 3 under that and it was still 2-3db hotter.
Having said that I do like DTS tracks and tend to hold off purchasing DVD's for a version that has both formats
Enough said, cheers
